help ...rubi wont move after sinking it
Old Mar 23, 2011 | 07:29 AM
jdnovak418's Avatar
Default help ...rubi wont move after sinking it
I have an 04honda forman rubi 500 with the hondamatic I sank it the other day got it running like 20 mins after now I have a grinding noise and it won't move in any gear can the couch be wet is there a drain ? Or could it have been a have just ate the clut
ch up
Old Mar 23, 2011 | 02:57 PM
JeffinTD's Avatar
It does have a centrifugal clutch, but it runs in the engine oil.
If you got grit and water into the hydrostat unit, though, it may have trashed it.
If it threw the oil pump drive chain, that would account for it not moving. The same oil pump supplies oil to the engine, so I wouldn't run the engine until you can get the oil pressure checked.
There is a pressure test port, but it is a thread you don't usually find on oil gauges, so it may be easiest to bring it by a Honda shop- at least to see what the oil pressure is.
Good luck with it.
Old Mar 24, 2011 | 08:19 PM
polymite's Avatar
you say you got it running in 20 min. please tell everyone you changed the oil and filter BEFORE you fired it up..... if you ever sink a bike, please change oil and filter ........if not it is just down hill from there.
Old Mar 28, 2011 | 06:56 AM
jdnovak418's Avatar
There is not any water in the oil but that don't mater its all pulled apart on my work bench as of right now ... the hondamatic unit is trashed
Old Mar 28, 2011 | 04:59 PM
JeffinTD's Avatar
Bummer. I was hoping it was something else.
Old Mar 28, 2011 | 07:12 PM
jdnovak418's Avatar
Me to 1300. Is more than what I paid for the whole atv
lonerider856
Oct 13, 2023 03:45 PM
Dewhound
Apr 20, 2017 02:25 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
Elkaholic
Sep 6, 2015 02:44 PM
