Wiring diagram or schematics on honda fourtrax 300
Hi Pierre. No, your posts are coming through. Maybe nobody has a schematic for that quad. I don't. I can tell you one thing about CDI's though. There is no way to check them to see if they sre good or bad. The only thing you can do is check everything else and if everything else is good and still no spark, or weak spark, it's a bad CDI.
if i crank the engine, i do get a signal from the cdi if i remove the terminals from the coil, but when i put them back on there is no signal and then the cdi starts heating up. i have tested the coil separately and it seems that the coil is shorted , but so does a borrowed coil and both coils does not give a spark when tested separately. funny thing is that the borrowed coil is said to be fine. any ideas? thanks.
TLC
Jul 11, 2015 02:28 AM
Chocobamofo
Jul 10, 2015 07:46 PM
