2 stroke pre mix oil which one
I use Maxima Super-M. It hasn't ever given me a problem and it works great. If you have a lot of money to burn, use klotz or some type of castor oil. Klotz is expensive, and castor will give you unbelievable power at the expense of long engine life.
Try Golden Spectro. They recommend mixing 52:1. This sounds like you don't get enough lube, but I have a buddy with a '94 Banshee that uses it and mixes as they recommend and he's never put in a top end and can still spank Banshees that come straight off the showroom floor. Good stuff!
redline racing 2-stroke oil, mobil 1 mx2t, and yamalube 2R are full synthetic, probly the best stuf on the market.
the redline is more expensive but in the world of go-cart racing it's the standard. they say it burns so clean on a well tuned motor that you can't even do plug checks.
2R and MX2T are about the same, but for a little less $$.
Use Golden Spectro I love it its the only oil I use, I mix it at 52:1 I think. I used Maxima super m before and my crank blew i dont think it had anything to do with it but you never know. I stongly recomend Golden Spectro
My web site
Http://www.geocities.com/baitmanv
My web site
I strongly reccomend AMSOIL series 2000 at 50:1. I used to run Klotz and Yamalube but I have had MUCH better results with the AMSOIL.
