400ex heli coil spark plug
Im going to attemp to heli coil my spark plug hole in my 400ex.anyone here have ever done this before?I was wondering what size kit do i need to get someone told me the thread was 14mm on the plug but i think its 12mm anyone know?Should i just do this with the head on with the grease or should i take it off the atv?I also have a bolt on the cylinder with a stripped head i been trying to loosen up if anyone has a suggestion for that its one of the bolts behind the heat protector
Thanks
Thanks
Believe me, you don't want to use a Heli-Coil on a sparkplug.
Your want to use this.
++ TIME-SERT Threaded inserts for stripped threads, threaded inserts, thread repair stripped sparkplug's, Ford sparkplug blowouts, threaded inserts threaded, repair stripped threads, stripped threads, inserts threaded inserts, Ford spark plug repair,
