Problem starting 2009 rubicon
Old Apr 27, 2011 | 07:46 AM
jstut's Avatar
Default Problem starting 2009 rubicon
Hi,
I have a 2009 Rubicon with only 120 miles on it. The first time it turn the key it will start up and then stall, which is normal when it is cold. But when I go to start it again it acts like the battery is dead. (it will barely crank) I screw with it for 10 minutes and walk away. I come back in 15 minutes and it starts right up and runs fine and will start up everytime until I leave it sit for a few weeks. Do I have a week solenoid or is it electronic??? Thanks.
Old Apr 27, 2011 | 10:37 AM
ddrumman2004's Avatar
Sounds like a weak battery to me.
Check charging voltage while engine is running if you can and see if the charging system is working properly.
No more than this atv is ridden, I would suspect the battery is dieing. It can happen.
Old Apr 27, 2011 | 11:03 AM
budedm's Avatar
I also think it is a battery and I think here's what is happening. The battery is strong enough to crank it once, but this draws all the power out of it. It would be fine if it didn't stall. But it stalls and so the engine hasn't had a chance to charge the battery back up to what it was before cranking. Then it doesn't have enough in it to crank it the second time. But then it cranks after 10 minutes. Why? Because when a battery like that sits for a little bit, it gains its strength back. So, then it starts and somehow you keep it from stalling and it charges it back up. So it starts all day. But a weak battery will not hold a charge for a long period of time. So the next time you try it, the same thing happens.
I agree to put a volt meter accross the battery while it's running. Not sure what the reading should be on a rubicon but I'm guessing 14.5 volts. If you have that, the battery is bad. If you don't have that, or if it's less than 12 v, there's something wrong with the charging system in the quad.
Old Apr 28, 2011 | 07:11 AM
jstut's Avatar
Default Starting
Thanks guys I will try that.
neilbedwell
Nov 10, 2018 11:02 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
neilbedwell
May 31, 2015 11:11 AM
1000gade
May 27, 2015 12:37 PM
