honda atc350x 1986 vs. 1985 rear end work
Old Apr 27, 2011 | 09:31 PM
LauraShush's Avatar
Default honda atc350x 1986 vs. 1985 rear end work
Help! Does anyone know if I can use an 86 axle bearing carrier in a 85 rear end?
Thanks so much for the help!
Old Apr 28, 2011 | 04:43 AM
sdm111's Avatar
2 strokes or 4
No the only way you can swap the carriers is to use the same year axle because the sprockets from the 2 different years bolts differently to the axle so if you use lets say an 86 axle in a 85 carrier the bolts that hold the sprocket to the axle will hit the carrier. I can't remember which years but one carrier is narrower than the other.
Wooodyii2
Nov 16, 2020 07:14 PM
Scott-Leigh
Jul 28, 2015 09:32 PM
scaldwellk
Jun 19, 2015 05:08 PM
TJM
Jun 11, 2015 01:28 PM
lovinhonda
Jan 25, 2000 09:17 PM
