2002 Honda 400ex please help
Old May 1, 2011 | 01:53 PM
Fox racing 9's Avatar
Default 2002 Honda 400ex please help
igotta 02 honda 400ex has lex exhaust and uni filter and i was running 20 50 weight oil and it was smoking horriably and then i switched back to 10 30 weight gtx not synethic and now it smokes a little but eats the oil idk wut to do please help it smokes and it smokes bad sometimes but not bad other times wen i ride but the heavyer weight was terrable so i need help
Old May 3, 2011 | 06:34 PM
Canadian07trx450er's Avatar
Does it feel like there is any power loss. When i had my 01' ex it started to smoke white one weekend but i did nothing then the next i was told it was smoking bad so i checked the oil and it had burn't all the oil. So i refiled it and after that weekend it had alot less power so i took it too my dealership it was'nt seized but the engine was worn bad and i needed it rebuilt. if any of this sounds familiar it could be you valves or piston possibly.
Old May 3, 2011 | 06:38 PM
jgar's Avatar
Sounds like piston rings, might be time for a top end rebuild.
Old May 3, 2011 | 09:04 PM
MrSummit's Avatar
It is my understanding that if it smokes on start-up and then clears, it is the valve guide seals.
Smoking that doesn't stop is the rings.
Might run a compression check to verify the rings are not sealing.
Old May 4, 2011 | 08:09 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Seems to be a common thing on the 400EX's. Nearly all of them smoked a little and quite a few smoked like a train. Most likely a top end rebuild will take care of it.
Old May 4, 2011 | 05:14 PM
420Pimp's Avatar
Rings bro, rings
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
MNatv89
Aug 12, 2015 06:00 PM
MNatv89
Aug 10, 2015 02:20 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
MNatv89
Jul 7, 2015 11:36 AM
