can you adjust suspension on 3 wheeler
Old May 5, 2011 | 02:13 PM
bass hunter's Avatar
Default can you adjust suspension on 3 wheeler
Hey, I was wondering if anybody knows how to adjust the suspension on 81 honda 3 wheeler it seems to ride rough, Is there an adjustment for a softer ride?
Thanks,,
Old May 5, 2011 | 03:46 PM
Bigborekit's Avatar
what model do you have ?
Old May 5, 2011 | 03:59 PM
I have 81 honda atc 200cc 3 wheeler
Old May 6, 2011 | 04:39 AM
Bigborekit's Avatar
I will assume its a 200m ? The only adjustment is the air pressure in the tires or the size of the tires. If someone put smaller tires on the atc it would make it ride rough. Make sure you have the right size on the bike then check tire pressure its usually about 3 pounds . Hope this helps
Old May 6, 2011 | 08:50 AM
Thanks Bud appreciate that! tires are the right size i do have alittle more air in them then i need, I will adjust the tire pressure that should help for sure, Thanks again,,
Hankey Pankey
May 1, 2018 01:33 PM
Stever6368
Aug 16, 2015 07:34 PM
stendori
Aug 14, 2015 12:57 PM
Mssarabug
Aug 10, 2015 12:56 PM
mdigitale
Aug 6, 2015 12:35 AM
