Will a rear diff from 86 350 4 trax fit a 95 300?
Old May 7, 2011 | 10:23 PM
kelpaso's Avatar
Default Will a rear diff from 86 350 4 trax fit a 95 300?
Or will the whole swing arm assembly change over? Not sure of the gear ratio's either. If not, how much is a good used rear diff from the 86 350 worth? (CDN) I notice used rear diffs are pretty scarce.
Old May 8, 2011 | 08:14 AM
papa hogg scoot's Avatar
Loved
Community Favorite
Not think will work. 350 fourtrax has two rear shocks,and final drive case and gears are different size,has axle housing tube,. What do you need? I can get aftermarket one for 300 fourtrax
Old May 8, 2011 | 11:14 AM
kelpaso's Avatar
Thanks Papa. The ring and pinion are shot and judging by the fluid so are all the bearings. So it would be easier if I changed the whole complete housing assy.
Kel
Old May 11, 2011 | 07:31 AM
Loved
Community Favorite
If you can find an good used one be good But make sure its not almost in the shape your is. If you are going to keep atv than put an aftermarket gear set and replace all the bearings and seals then you will know what you got when done.
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
Sep 9, 2015 10:56 AM
John Reed
Sep 9, 2015 03:46 AM
Jason Campbell
Sep 7, 2015 02:25 PM
black_thunder
Sep 7, 2015 01:24 AM
