need help banshee misfires?
Old Mar 12, 2001 | 08:53 AM
r440's Avatar
i have a banshee that mis fires when it gets warm then sometimes quits,let it cool off for a bit and it will start and run great,toke the THORS off it and it still does it,any info would be appreciated,I'm leaning toward the stator thanks
Old Mar 14, 2001 | 08:34 AM
r440's Avatar
bring to top
Old Mar 15, 2001 | 10:32 PM
jts's Avatar
jts
Change the jets
Old Mar 16, 2001 | 09:00 AM
seven's Avatar
My banshee did that right before the cdi box went out.If it ends up being the stater you should look on ebay,they have them on there all the time.
Old Mar 16, 2001 | 09:13 AM
AdrenalinFreak's Avatar
Check your coolant system out. If the motor is overheating it will slightly sieze. I had this happen because of lean jetting, Didnt have a clue that I had leaned out because we were on an unfamiliar trail. Engine just kinda burbled for 2-3 seconds and died like I hit the kill. It wasnt REAL hot but it was warm. Dont know if there is a temp gauge shutoff built in, or if its cause I "sqeaked" the pistons.
Check your jetting, If your running lean it will sqeak the pistons as I mentioned. If you dont feel like pulling the carbs apart, Just duct tape ¼ of your airbox intake off. This will lean the air out a bit. If it stops stalling then it is your jetting.
Another possibility here is the carb float bowls. If they are not set proper it will cause fuel starvation at your top end.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
