82 ATC 200e starter button need help
Old May 11, 2011 | 11:38 PM
Slash0311's Avatar
Default 82 ATC 200e starter button need help
I bought this old ATC for $50. It doens't run and the starter button has been removed. I found one on ebay and ordered it.
Does anyone have any pics of where the wiring connects from the button to the bike? Or can anyone explain where the wiring attaches? The rest of the wiring seems complete and in good shape. The engine seems to spin freely and eveything else except for all of the old cables on the brakes and throttle are in good shape. I'm looking forward to trying to fire this beast but I'm trying to figure out this crazy button.
Thanks for any help.
Old May 12, 2011 | 07:53 PM
sdm111's Avatar
2 strokes or 4
The start run switch is actually a ground switch, so if the switch has been unplugged it will run if you get it started you would either need to choke it out or pull the plug wire to kill it. As far as a schematic it's pretty much plug and play each plug is different so they can't be crossed. The plug should be located under the gas tank on the left side near the handlebars under a rubber boot. Or on the left side where your inner knee would be.
Old May 12, 2011 | 07:59 PM
Slash0311's Avatar
On this trike, the starter button is seperate from the kill switch/headlight switch. The button and the switches each have seperate wiring harnesses. The starter button has two wires with a male and female connectors. I double checked this evening and can't find places for them to connect.
Thanks for the reply
Old May 13, 2011 | 04:00 AM
williams9394's Avatar
Default idiomas en el extranjero
Hi there. Ok first off I would appreciate any and all help and advice with this thing.
I have a 1984 Honda ATC200E. I do not believe this thing has actually ran for quite some time, other than being possibly pull started a few times.
Here I go. First off the starter button was missing and we have purchased a new one.
curso en el extranjero
inglés en el extranjero
escuelas inglés Valencia
Old May 13, 2011 | 04:53 AM
sdm111's Avatar
2 strokes or 4
3WHeeLeR WoRLD - ATC200E click on it to enlarge
akguy31
Aug 31, 2019 04:34 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
black_thunder
Sep 7, 2015 01:24 AM
Pahuntman
Sep 5, 2015 11:07 AM
