Valve Cover Gasket
Old May 14, 2011 | 04:20 PM
Polaris500Sportsman's Avatar
Question Valve Cover Gasket
I'm gonna replace my valve cover gasket on a 06' Sportsman 500 EFI HO. Is there any type of adhesive that i need to use before putting the new one back on?
Old May 14, 2011 | 06:12 PM
If using the OEM they are put on dry from the factory,BUT when I changed gaskets, I used just a very thin film of 1104 Threebond(same basic product as "Yamabond" from the old days) around a new gasket. I HATED leaks of any kind anywhere! OPT
Old May 14, 2011 | 07:14 PM
Is there anything I can use from a hardware store OPT?
Old May 14, 2011 | 07:22 PM
Look for any sealant that is oil resistant. They still have good old Permatex (nasty stuff) and other type gasket sealants. The BEST sealant in my opinion called 'hallemier" (NOT the right spelling!!) available at Auto Zone,O'Reilly's,Napa,etc. Its a blue type sealant in a small tube,used a lot by Rolls,Mercedes Benz originally. OPT
Old May 14, 2011 | 07:47 PM
Thanks OPT. Is the valve cover difficult to remove? The way it looks i just take out the half dozen bolts and it should pop off correct?
Old May 15, 2011 | 07:22 AM
JCDEYO25's Avatar
Not sure how the 500's are set up but make sure it's not the pcv breather on the top that's leakin...I originally thought it was a valve cover gasket on my 700 but after a closer look it appears to be the breather on the top leaking oil down...Just a thought...
I am gonna replace mine with a billet one ....The stock ones are plastic and seem to warp after some time...
John
Old May 15, 2011 | 08:17 AM
Just eight 8 mm bolts to remove and cover will come right off. OPT
Cole Hadden
Jun 15, 2025 09:05 AM
Njrider1230
Jul 29, 2023 05:16 AM
rawbdiggity
34
Sep 2, 2015 02:16 AM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Countrygirl1976
Jul 13, 2015 10:08 AM
