500 creep when cold
Old May 14, 2011 | 09:49 PM
xplorerman's Avatar
Default 500 creep when cold
Hello i have a 2003 sportsman 500 it started creeping only when it is cold works good when it worms up i would like to know what i should do to fix it
Old May 14, 2011 | 09:52 PM
atvkiller's Avatar
what does it sound like is creeping on it
Old May 14, 2011 | 10:03 PM
xplorerman's Avatar
lol the hole atv
Old May 14, 2011 | 10:07 PM
atvkiller's Avatar
haha lol well to start with go through all the grease fitting on the drive shaft and all around the bike my 2003 400 outlander is getting the same way but its really nothing but stuff not oiled up as well any more i greesed every thing up and mine quit creeping
Old May 14, 2011 | 10:10 PM
xplorerman's Avatar
sorry when i said creeping i meant moving own its own with no throttle
Old May 14, 2011 | 10:20 PM
atvkiller's Avatar
aw sorry was a little confused ther try turning your iddle down a little sound a bit to high if its idling to high it can cause it to move when its iddling due to the motor if running a little faster
Old May 14, 2011 | 10:24 PM
xplorerman's Avatar
i adjusted the idle down until it almost stalls out and it still dose not seem to help
Old May 14, 2011 | 10:27 PM
atvkiller's Avatar
is it an atomatic or manual if its a automatic your clutch is sticking it sounds like so its grabbing the belt all the time might just have to clean the clutch up
Old May 14, 2011 | 10:46 PM
xplorerman's Avatar
thanx i will give it a better cleaning and see if that fixes it it is a auto
Old May 14, 2011 | 10:50 PM
atvkiller's Avatar
ya thats what it sounds like its sticking check on line to see what you can use to clean it out good i forgot what you would use to clean it
