honda 185 s three wheel atv
Old May 16, 2011 | 12:41 PM
gdskala's Avatar
Default honda 185 s three wheel atv
I need to tow this atv but when i do the engine turn over like once and then stops . it almost starts with recoil start so i think if i could tow it it would start but cannnot get engine to engage and turn over any ideas
Old May 16, 2011 | 12:54 PM
Doctorturbo's Avatar
GOT BOOST!
What do you mean it stops?
Could be lots of things but sounds like a clutch problem to me.
What gear you trying to tow it in?
Old May 16, 2011 | 07:55 PM
Slash0311's Avatar
If you are asking how to tow start an ATV then that's pretty easy. If it has a manual transmission with an automatic clutch, left the shift lever into the up position and pull. (The transmission won't shift into first gear until the lever is moved into the lower position completing the shift.) Once you think you have enough speed to start it, move your foot so the gear shifter will move to the lower position completing the shift. The atv will then be in gear and should start, if it's going to.
greg74
Sep 10, 2019 03:03 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
Jul 22, 2015 05:00 AM
Jul 21, 2015 03:03 PM
CRamshaw777
Jul 18, 2015 05:46 PM
