2011 sportsman 500 ho belt
Old May 22, 2011 | 08:06 AM
c_mack's Avatar
Default 2011 sportsman 500 ho belt
I was our riding yesterday and at 240 miles the belt broke i do not drive my bike hard i do how ever have 27inch Kenda Executioner tires with 1.5 in wheel spacers
could this be the issue?
Old May 22, 2011 | 08:42 AM
Either from the added strain on the system OR could have had defective belt that finally separated. Try another belt and with in a couple hundred miles you will know! If you drive around in hi range a lot at slow speeds can cook a belt,big tires or not! P.S WELCOME to the forum! OPT
Old May 22, 2011 | 08:43 AM
c_mack's Avatar
im calling the dealer on Tuesday to find out if its covered under the warranty its only 2 months old
Old May 22, 2011 | 08:45 AM
NOPE! Belts are not covered like they used to be,BUT no harm trying. Take the old belt to see if you can find any defective area ,THEN it can be warrantied! I had a chart on the wall showing about 9 different ways a belt could be destroyed and only 2 were warranty considered . OPT
Old May 22, 2011 | 08:49 AM
c_mack's Avatar
first and last Polaris i buy lol on the web site it does state the belts have a lifetime warranty unless i m reading it wrong
Old May 22, 2011 | 08:52 AM
USED TO BE! Belts are taken on a case by case situation now! OPT
Old May 22, 2011 | 08:57 AM
c_mack's Avatar
we will see i will let yea know if not they are only 50 bucks i am putting my stock tires on to see if there is a change
Old May 22, 2011 | 11:21 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the biggest reason for belt failures is most likely excess heat build up form stress. meaning you should be using low range w/ the bigger tires on it when you playing hard w/ it say in mud or towing. the bike when going slow is not turning the clutches fast enough(like 5 mph for extended time) to keep the belt cool. the manul says to use low while going under a certain speed(at least it use too) for just that reason i do beleave. like otp says i'm guessing(unless you have a great dealer) they won't warranty it. if they can find one burn mark on the belt then theres thier reason for denieing it
Old May 22, 2011 | 12:53 PM
john luttrell's Avatar
I agree, taller tires and slow speeds in high range equals a lot more heat for the belt to deal with; I personally would upgrade the clutch with a kit designed for taller tires if I was going to run taller than stock tires.
Old May 22, 2011 | 04:15 PM
james feeney's Avatar
Wouldn't the after market tyres void your warranty anyway, at least in your dealer's eyes?
JF
