Trail Boss 250r/es Crank Case Bearings
Old May 22, 2011 | 11:25 PM
86trailboss250r/es's Avatar
Default Trail Boss 250r/es Crank Case Bearings
Hello everyone this is my first time using a forum, but i recently acquired a 1986 trail boss 250r/es 2x4 quad and i need to replace the crank case bearings, i was wondering what specialty tools and the procedure to do the job requires. also help would be greatly appreciated in locating the bearings online, I have searched for over a week trying to find then and every search ends unsuccessful.
Thanks All
Old May 23, 2011 | 05:32 AM
Thanks All
If you have access to a bearing separator will help to remove bearings from crankshaft. PLUS separator and HEAT (propane torch) is necessary to remove the oil pump drive gear from the crank. As far as bearings you can get em cheaper at Napa,Auto zone,etc. Bearings have a"universal" number on them such as 3605,etc that most auto parts will carry.Complete gasket kits are available along with seals online.Cheap Cycle Parts are cheaper than dealers and are OEM parts. Tucker Rocky,Parts Unlimited,etc are a source for after market Pistons,gasket sets such as (COMETIC,VESRAH). Welcome to the forum! Hope this gets you started. OPT
Old May 23, 2011 | 11:26 PM
Thank you this is a great help to start me on this project
Ean
Dec 19, 2022 08:48 AM
toonces
Jul 21, 2015 02:40 AM
clsharky
Jul 13, 2015 02:07 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
