polaris predator 90?
Old May 24, 2011 | 12:08 PM
darian26's Avatar
Default polaris predator 90?
ok i have a a dumb question. i have a polaris 90 and the auto mixer isnt mixing. And i want to take it off and just straight up mix the gas. but, i dont know what ratio of oil to gas i should use. can you help me out?
Old May 24, 2011 | 02:26 PM
The 90 oil pumps are very dependable unless they are damaged,etc. Is it still connected to the split cable?? OPT
Old May 24, 2011 | 03:01 PM
darian26's Avatar
the oil light came on yesterday and wasnt turnign off. and then the motor started clicking. so i checked the oil and it waas full. so i put 2 and 2 tomgether and just figured that it wasnt wprking. and i thought that just mixin the gas would be much simpiler. so thats what i want to do. so i just need to know the ratio
Old May 24, 2011 | 03:27 PM
BLOCK off the small oil line leading to the carb and mix 40-1 ratio. Oil level sensor float could be bad(common problem),showing low oil when the tank is full!! If small line to carb has a small amount of oil on the end of it,the pump is working!! OPT
Ramman1
Aug 11, 2022 01:53 PM
1966F100
Jul 24, 2015 02:17 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
