05 Polaris 800 EFI Fuel problem
Old May 24, 2011 | 09:16 PM
knarfd's Avatar
Default 05 Polaris 800 EFI Fuel problem
When I turn the key to on the fuel pump should come on bit it doesn't.
I tried to put power directly to the pump and it still doesn't run.
I checked for continuity and there is none. Do you think the fuel pump is done. By putting power directly to it it should run right.
Please help me.
Thank You
Old May 24, 2011 | 09:51 PM
Sounds like you found the problem! Still shows on parts breakdown as a tank assembly,BUT other sources available for just the pump assembly only. NAPA is one source plus others can hopefully direct you to the best place. Polaris is offering separate fuel pumps now,but doesn't show on my list,BUT will be costlier! OPT
Old May 25, 2011 | 08:52 PM
knarfd's Avatar
Thank You for the info. I ordered a fuel pump and strainer from one of our local automotive parts store for a total of $150. I hope it will work. I will post the results of the hole process once it's done.
Old May 26, 2011 | 08:02 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
airtex is one company form napa i belave that works as well as others. they were around $120 a few years ago, so that isn't bad.
green giant
Jul 13, 2017 12:07 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
cornermike
Jun 3, 2015 07:27 AM
trick33
Feb 10, 2001 08:27 PM
Burrlok
Sep 24, 2000 12:09 AM
