Front wheeles lock on 2005 polaris ATP
Old May 24, 2011 | 11:32 PM
Throneperformance's Avatar
Default Front wheeles lock on 2005 polaris ATP
Hey does eneyone know why the front wheeles would lock on once you hit about 5 miles an hour. I read the thread regarding the roller cage so I removed the front drive case and pulled the cage found no damage but some wear. So I replaced it and the roller kit from John Deer put it all back together and the samething happens. Does anyone have any helpful info I sure could use some. Any good advice would be appreciate it.
Thank you,
Mark
Old May 25, 2011 | 05:42 AM
Thank you,
Mark
Did you replace the armature plate while you were in there?? That could be one of the problems?? OPT
Old May 26, 2011 | 12:08 AM
No I did not but after your reply I pulled it apart and replaced the armature plate and did a through cleaning and that took care of the problem. Thank you for the information.
Mark
hoopduerr
Jun 10, 2015 03:00 PM
UPLou
Jun 7, 2015 09:42 AM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
