axle removal problem
I read as much as I could today about removing my axle so I am at the point where I am taking it out of the transmission but its jammed on there... can I change the cv inner boot with out taking it right off? I've been pulling for the last half an hour and it just wont come off
the cv joint came apart on my 05 800, when trying to remove them from the rear diff.
so i pulled one right apart. welded a nut to the remaining peice and put the threaded slide hammer on it. mine were clicking so i replaced both axles.
Yeah,that was was the worst part when they brought em in for boots and the drive shafts were already shot! After pulling a couple apart and having a 3 or even a 2 legged "dog" to move around the shop until we got new ones in,I stared telling them right off on the click clacking worn out ones, CAN"T guarantee a new boot would help and more than likely I would pull the damn thing apart doing so! Some I could convince to just go ahead and order the drive shafts,some had to see for themselves! POINT is always check your boots often,replace before any damage can happen AND when they are just plain worn out,Just go ahead and bite the bullet! OPT
toonces
Oct 16, 2019 12:11 PM
ranvette
Jul 4, 2015 06:13 PM
