06 Sportsman 500ho
It starts and runs just fine but when I start to go it will sputters and then dies, the check engine light comes on when it dies. It will start right back up and Idle just fine till I go again. Ive changed the oil and fuel filter and have checked for any lose wires and have not found anything wrong. Any suggestions on what to do or where to start?
Thank you for the sugestion. I was wondering if I should check other thing like the MAP or the cam position sensor before I go buy this part. I checked the dealer and they didnt not have a recal on it, so I was just wondering if there would be something else besides that. Its kinda expensive.
Seth Hansen
Seth Hansen
You posted as having a 500 HO this is a CARB model. If you have a 500 efi,THEN yes you can check for any bare wire on the crank sensor harness where it rubs against the starter motor,but most of the time erratic idling,popping back was caused by a short in the map sensor harness or connector. Repair kit number for the map sensor is #2676315. IF you do have the carb model then most of the problems were the ECM and its under a Service Safety Bulletin and should be replaced at no cost!! OPT
Yes sorry it is the efi edition. I checked all wires and they looked fine. I will check the map better. It idled fine, then I start going about 10 15 feet and it just dies. Thanks for the help
Map sensor wiring short is my best guess! the wires can break internally and also the connector can have problems. We replaced a LOT of harness kits! they come with a new connector harness,shrink fit connectors and instructions. They are very SMALL wires and you might need to read the "sticky" about the wires OPT
Not with out connecting to Digital Wrench! You can see if it throws throws the code number on your speedo as a start(can't remember if its code 45?). Plus basically all the rest you can do is check for obvious bare wires. OPT
hey old polaris tech i am new to the fourm aswell and how do i post my own thread?? thanks because i wana know a link to get a frre honda trx90 repair manual and or videos on how to rebuild an engine
