04 400ex problems
Old May 30, 2011 | 08:33 PM
RandK's Avatar
Default 04 400ex problems
we just recently bought a 2004 400ex it was running great, and then we went on a ride and it died on us we cleaned the carb, and checked the plug...we tryed to pull start and when it started up it was aloud clicking noise and only stayed started for like 2 seconds..can anybody help?
Old May 30, 2011 | 10:19 PM
Doctorturbo's Avatar
GOT BOOST!
#1. Take a compression test.
#2. Go from there.
Old May 31, 2011 | 10:04 AM
RandK's Avatar
thank you ...we checked and it does have compression..anything else?
Old May 31, 2011 | 11:16 AM
GOT BOOST!
What was the compression number?
It depends on how it died also. Did it just die like you turned the key off? Or did it start to run crappy and then die slowly?
If it's getting gas and spark I would give the cam timing a good looking at. I would also look over the valve gear and see if everything is good to go.
Good luck and let us know what you find.
Old May 31, 2011 | 05:14 PM
RandK's Avatar
im not to sure about the number..and when it died we were going to turn around an it just stoped it didnt sound any diffrent and wasnt running any diffrent...and do you know how to do the timing and the vavels?
thanks for your help
Old Jun 3, 2011 | 03:25 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Those things are infamous for stretching the time chain. It will start with a light click and continue to get louder and louder. Not loud enough that it brings tons of attention but, if you listen it will be there. It may have got loose enough to break the guides causing much noise.
I wouldn't try to start it until you tore down enough to check the chain. You can cause major damage. Get a manual on it. It will show you how.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
