jetmoto 150cc.. running issues
Old Jun 18, 2011 | 02:07 PM
pvillefball421's Avatar
Default jetmoto 150cc.. running issues
I found a used hensim 150cc sport Ive been told there the same as the jetmoto 150cc sport quad. the seller states (Starts and runs, but needs work, stalls if throttle is pressed hard, I cleaned the carb and replace fuel filter but still has problems moving.) I came here to hopefully get some help before I buy the quad.
Old Jun 18, 2011 | 05:28 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum pvillefball421!
I think he missed something in the carb rebuild.. Unless it still has the stock spark plug.. NGK C7HSA is a good replacement
Old Jun 19, 2011 | 10:05 AM
do you mean like a clogged jet or something?
Old Jun 19, 2011 | 11:39 AM
KTM Patrol
Former Chinese POW!
Yes... Id guess its got a plugged pilot jet... smallest hole.. easiest to plug..
Old Jun 19, 2011 | 11:58 AM
KTM Patrol
Former Chinese POW!
The other thing thats easy to plug is the tube the main jet is held in.. about a dozen or so small holes in the side of this tube.. but if they were plugged, it wouldnt keep the engine from running..
Old Jun 20, 2011 | 02:13 PM
ok so once I pick the quad up and get it home I should break down the carburetor to get to the jets?
Old Jun 21, 2011 | 07:27 AM
KTM Patrol
Former Chinese POW!
Yes
Old Jun 21, 2011 | 05:06 PM
can i use trottle body cleaner to clean the jets? and like a tooth pick
Old Jun 21, 2011 | 05:29 PM
KTM Patrol
Former Chinese POW!
I use carb cleaner and compressed air... throttle body cleaner should work ok.. you also want to remove the fuel screw(on the bottom) and spray cleaner thru all the passages and little holes in the carb.. keep carb/throttle body cleaner away from anything made of rubber... if not it has a tendancy to grow to a useless size..
Old Jun 21, 2011 | 05:35 PM
ok thanks for the quick response> depending on how easy this is i might try to add some sliders or rollers and maybe some other cheap upgrades i want to take it upstate. how reliable are these engines if i were to put upgrades into it. and is there a diy writeup about how to dissemble these atvs or at least the carb
