Bearing-Hubs
Old Jul 2, 2011 | 12:51 PM
Spdecat's Avatar
Default Bearing-Hubs
Just wondering if it's just bad luck or do you think my front hub's are worn thus need replaced . I'm in the process of removing my front axles and when I removed my front hubs the new bearing that I just installed like 1500 miles ago came apart in two pieces . One section of the bearing was still attached to the hub while the other section with the ***** remain in the strut . Should I install new hub's and new bearing again ? thanks
Old Jul 2, 2011 | 07:37 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
not sure but it shouldn't have gone bad that sooon unless not getting lubacation or maybe you tightened to tight or maybe too loose, but the ***** would be worn i would think?
Old Jul 2, 2011 | 07:54 PM
Had em do this before. If bearings aren't worn or dry just add a little grease and stick it back together! Since its basically a two piece bearing it will sometimes do this! OPT
Old Jul 2, 2011 | 09:29 PM
Spdecat's Avatar
Thank's that's what I'm going to do as the bearing are like new and still full of grease . What about adding grease as I read once that mixing two different greases can make things turn to slush . I have Amsoil wheel bearing grease I figure that should be fine . Are my hubs worn and that's why it came apart in two pieces ?
I'm changing the back axles also what a pain been at it all day still can't get either side to release . One side pulled apart all I got left is the inner steel part of the cv joint what a pain in the butt , I gave up for the night .
Old Jul 2, 2011 | 09:37 PM
Hub bearings can get stuck on the drive shaft and separate leaving half in the hub,this is a common thing. Just any good grade of wheel bearing grease will do. OPT
