2002 sportsman 500
Old Jul 4, 2011 | 04:00 PM
bigcam400's Avatar
Default 2002 sportsman 500
found a deal on this an will be buying it,...how do i tell if its a H.O.?? beggest question,..the shifter is shot,.what other models will shifter work from?? buddy got a 96 xplorer i hope shifter on it will fit!! real exighted bout this sportsman!! its the wetlands camo one with chrome wheels an super swampers an a wrench,aftermarket front an rear bumpers,....900 bucks cant see going wrong with it!!
Old Jul 4, 2011 | 04:33 PM
H.O. came out in 2003, piston was different #,BUT if its any consolation the cams and valves are the same #'s from 2002-2011.
As far as the gear selector there are differences and different numbers,BUT may be can use the 96 but the mounting bracket will probably have to be changed/altered?? NOT entirely sure. BUT also if you're getting it for 900 bucks then $216 for a brand new shift box through Cycle Parts Warehouse may be a better way than trying to "southern engineer" a different year shift box that will in all probability won't last very long itself !! OPT
Old Jul 4, 2011 | 04:37 PM
bigcam400's Avatar
H.O. came out in 2003,BUT if its any consolation the cams are the SAME number from 2002-2011.
As far as the gear selector there are differences and different numbers,BUT may be can use the 96 but the mounting bracket will probably have to be changed/altered?? NOT entirely sure. BUT also if you're getting it for 900 bucks then $216 for a brand new shift box through Cycle Parts Warehouse may be a better way!! OPT
guess ill get better look at it when i get it home,..216 ant bad to do it right!!,..but think itll be a good quad with a lil tlc!! an will look real cool beside my xplorer!!
Old Jul 5, 2011 | 07:56 AM
pwssr's Avatar
H.O. came out in 2003, OPT
It was actually 2001....
Old Jul 5, 2011 | 08:58 AM
Yep! Caught me!! Sorry! Opt
Old Jul 5, 2011 | 05:45 PM
bigcam400's Avatar
soooo,....whats the deference ib a 500 an a 500HO??
Old Jul 5, 2011 | 06:03 PM
pwssr's Avatar
HO says "HO" on the tank....
Old Jul 5, 2011 | 06:07 PM
bigcam400's Avatar
an this means ?? what?? just more decals???
Old Jul 5, 2011 | 08:27 PM
user493's Avatar
Moto Psycho
HO has 40mm carb instead of 32mm, a different cam, and the clutching is different IIRC.
Old Jul 5, 2011 | 08:35 PM
HO was basically just a change on the cam on the 2001 models and up, piston change on the 2002-2011 models and going to the BST 40 carb up from the BST 34. Just gave it a little more power,BUT the BST 34 carb had far less problems on leaking,easier to change needle and seats and better float system(IMO),and didm't have the funky wrap under carb idle adjuster that always had the holder spring break! OPT
