want mods for my king quad
Old Jul 5, 2011 | 11:58 PM
15caldwellma's Avatar
Default want mods for my king quad
Does anybody know if it is possible to put a turbo on an 09 King quad 400? im looking to spend around $1000 or less on one for it. If anyone knows if this is possible and/or how much one would cost, please let me know, THANKS!!!
Old Aug 21, 2011 | 12:48 AM
King Quad's Avatar
Why not have your clutch machined.
read up on Mad Mike and Airdam clutch work.
They both will machine your clutch to make the belt sit lower for quicker engagement. I did it to mine and it got rid of all the lag.
Also you could consider a copperhead VDI.
It is an Electronic control module (ECU) that replaces the stock one.
All ATV's are regulated from the factory to retard the motor so new riders don't hurt themselves.
A VDI is 500 dollars assuming they make it for your model and the machine work will be between 200 - 500 dollars depending what you have done.
Also if you do the clutch work ask for lighter rollers.
You wont need to buy a new spring on the Suzuki you can compress and twist the secondary to obtain faster engagement.
While this does not directly answer your question it puts you on the right path to unleash your beast.
Old Aug 21, 2011 | 12:49 AM
King Quad's Avatar
Decided to check...
Shopping Cart
This is the link to the 450 VDI.
Call them to see if you can use it for your 400
Cole Hadden
Jun 15, 2025 09:05 AM
Jul 22, 2015 05:00 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
D-Hagz
Jul 4, 2015 02:19 AM
