Squeak in rear axle on 250ex
Old Jul 10, 2011 | 10:42 AM
taxman's Avatar
Default Squeak in rear axle on 250ex
I'm getting a loud squeak in the rear axle of differential on my 250ex. I jacked it up and rotated the axle---you can hear the noise in one area as I rotate the axle on full turn. I haven't done anything else yet. Does the rear axle fluid ever go completely dry?
Old Jul 10, 2011 | 09:22 PM
budedm's Avatar
I bought a used Recon and the diff was pretty empty. It shouldn't lose any but for a few bucks, if it's low, top it off. Don't ride it if it's low.
Old Jul 11, 2011 | 01:20 AM
TexasRoadlawyer's Avatar
No Ruts, No Glory
I would look at the bearings as the source of the squeak as opposed to the gears inside the rear drive (note, it is not a differential)
Open up the drain plug and see what the gear oil looks like, but unless it has a milky appearance, I'm betting it is the bearings
Old Jul 11, 2011 | 05:33 AM
taxman's Avatar
It was the rear brake dragging. I fixed that and no more noise or dragging. I'm going to check the fluid anyway though. Thanks...
mywifesquad
8
Sep 21, 2015 08:20 AM
Jason Campbell
Sep 7, 2015 02:25 PM
black_thunder
Sep 7, 2015 01:24 AM
Canamaniac!
Sep 4, 2015 06:44 PM
snowolson
Aug 31, 2015 03:51 PM
