07 honda rancher front tire question
Old Jul 13, 2011 | 04:36 PM
Coon slayer's Avatar
Default 07 honda rancher front tire question
As the title says I have a 07 honda rancher. I ride this thing monday-friday every week for work. I am in the hill country of texas and it is pretty rocky.
My question is both front tires seem to have to much play in them. Can move them back and forth. I replaced wheel bearings on one side. I still aint happy with it seems loose to me still. What else can I check on and see what is causing the movement?
Thank for the help.
Old Jul 13, 2011 | 06:09 PM
HMT Racing's Avatar
Tie rod ends inner and outer probably need to be replaced. Also check the ball joints.
Old Jul 13, 2011 | 08:39 PM
K i am going to tear it apart again on friday and see what i find out.
Old Jul 14, 2011 | 09:04 PM
Is there any bushings that may need to be checked too. I know there is a bushing where the shock connects.
Old Jul 14, 2011 | 09:34 PM
Or what about pulling the axles and repacking all the bearing in the cv boots?
Old Jul 17, 2011 | 10:32 AM
I got it all to work. I pulled it all out and used all ***** wheel bearings. I took the seal out of the wheel bearing and packed it full of grease. They was on the light side for grease i thought. Also packed the dust seals with grease. Put it all back together. Before I put the hub back on I used a grease needle and pumped it full of grease. Got it all back together and It is tighter now then when it was brand new I think. I am going to replace the ball joints and all that stuff here soon. Thanks for the help guys.
Old Jul 17, 2011 | 12:39 PM
budedm's Avatar
It's a great feeling when you put things back as good or better than new, isn't it?
Old Jul 17, 2011 | 05:56 PM
yep and it is amazing what a little grease can do in the right spot. I didnt figure it would need that much grease.
neilbedwell
Nov 10, 2018 11:02 AM
txkevin
Sep 21, 2015 02:02 PM
ROWALKER
Jun 15, 2015 05:38 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
Rancheres4X4
May 5, 2000 02:09 AM
