05 Ranger...Starting Problem
Old Jul 13, 2011 | 11:20 PM
jbow05's Avatar
Default 05 Ranger...Starting Problem
My '05 ranger has been sitting for almost a year. I tried to start it and it won't kick over. What should I do?
Old Jul 14, 2011 | 06:45 AM
budedm's Avatar
By kick over I assume you mean it cranks (good battery) but won't fire up. It probably has bad gas in the carb. Gas will turn to varnish in a few months. After a year, it's a pretty sure thing that bad gas is the problem. You'll most likely have to remove the carb, take it apart and clean it. Also, get rid of the gas in the tank. But before you do all that, first drain the gas and put fresh in. Then spray some carb cleaner in the carb as you crank it. Then see if it will start with some starter fluid in the carb. Or, remove the plug and put a tablespoon of gas in the cylinder, replace the plug and try starting it. If you can get it started, continue to spray carb cleaner in the carb while it is running. A little at a time. Don't put so much in that it stalls. But in the furtue, you may want to clean the carb anyway. And when you store it, put some Sta-bil in the tank. Get it at any auto store.
Old Jul 14, 2011 | 08:23 PM
jbow05's Avatar
Default 2005 carberatur access
How do I access the carberatur to spray the carb cleaner and starting fluid?
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
