Help pleas 300 2 sstroke carb
Old Jul 16, 2011 | 08:04 AM
crabbott's Avatar
Angry Help pleas 300 2 sstroke carb
I'm an old hat at working on cars, and have recenlty been interested in 2 stroke and 4 stroke engines. So, I paid $150 for a very rough '99 xpress 300 2 stroke. I have rebuilt the carb, added a new coil, spark plug. I cannot get the thing to turn over. The starter is toast, so I am using the pull start.
I have also checked for a short to ground on the terminal board, seems ok.
I thnk my problem is in the carb. Does anybody know how to adjust the choke, or common problems that sound like the ones I'm having? THX!!!!
Old Jul 16, 2011 | 08:25 AM
Welcome to the forum! First thing I would do is to check compression. If it doesn't have at least 100 psi then you would have to address this first. Must have top and bottom compression(crank seals)! Leaking or also blown crank seals can cause problems also! Just like a car has to have air,fuel,compression and fire. OPT
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
