What type of oil, 2004 400
Old Jul 18, 2011 | 08:53 AM
budedm's Avatar
Default What type of oil, 2004 400
I'm borrowing a friends 2004 Arctic Cat 400 automatic, 4wd. I want to give it an oil change but am not familiar with the quad. Can I use motor oil? Regular 10-40 or 10-30? I live in SC.
Old Jul 18, 2011 | 10:39 AM
turbodieseli4i6's Avatar
I would ask your friend what he uses! If someone changed oil in one of my engines with out asking me first, they wouldn't get it again!
I have a friend that borrows my log splitter. To make it easy I keep a extra quart of oil with the splitter and tell them that is the only oil to put in it!
Old Jul 18, 2011 | 01:28 PM
budedm's Avatar
Good idea. Ok, I'll ask him. Thanks.
Old Jul 18, 2011 | 01:53 PM
No problem! It's great that you are going to change the oil for him, but it would be a waste if he already serviced it.
Old Jul 18, 2011 | 02:00 PM
budedm's Avatar
He doesn't maintain his things. I borrowed it last year and bought a new choke lever, fuel shut off ****, throttle cable, changed the oil, adjusted the toe, and a few other things. He always likes when I borrow his stuff. lol
Old Jul 18, 2011 | 02:11 PM
I need a winch and a plow on mine! You want to borrow it! LOL
Keep it up.
budedm's Avatar
lol
Old Jul 20, 2011 | 12:36 PM
swampyjunior's Avatar
The oil will need to be "wet clutch" safe. Regular auto oil ususlly has friction inhibitors that are not goo on the AC wet clutch.
I have had good luck with Valvoline ATV/Motorcycle oil. It is a wet clutch safe dino oil that costs about $3.00 a quart. You will need 4 quarts of oil (actually will only use just over 3 with a filter change) and a filter.
IF you are just looking for something to do... I need the oil changed in my truck, some wood split, and the yard mowed. I have been spending "too much" time fishing according to my wife. I always answer with "I have not yet begun to fish!...honey"
Swampy
Old Sep 19, 2011 | 11:09 AM
budedm's Avatar
Ok, I have asked him what kind of oil and he said he has never changed it. Someone else always does it. The manual says 10-30 or 10-40 but does not say whether it needs to be wet clutch safe.
Old Sep 19, 2011 | 10:22 PM
mudslinginfool's Avatar
Does it in the Mud!
use wet clutch safe oil. i just replaced my clutch shoes($150) b/c i didnt use it,well actually i had added seafoam which is NOT wet clutch safe. just use arctic cat oil,no question then. may spend a little more,but its the correct oil and you wont have to repair it later. when it comes to oil,ask yourself,Is it worth the extra $10 for the correct oil or to rebuild the engine??!!
