need some help on a 2005 honda recon 250♠
Old Jul 18, 2011 | 09:13 PM
powerstroke08's Avatar
Default need some help on a 2005 honda recon 250♠
i have a honda recon 250 and it hasnt been running forever because i acccidently forgot to put oil in it and one day i was driving it and it just came to a stop and i had to push it all the way home and my dad checked on it and it didnt have oil in it and i know i wass stupid cux i was only like 12 or sommething but what do you think is wrong with it and how much will it cost to fix it ? i know the engine mite be blown but idk , cant you repl;ace like o rings or something and that WILL fix the problem i need some help so give me some suggestions what to do . thank you
Old Jul 18, 2011 | 11:08 PM
nelson61339's Avatar
From: trx 90, 2010 honda fouurtrax es recon 250, 2011 honda efi es rancher 420
put new o rings in, use sealent to seal cracks and, PUT NEW OIL IN IT!!!
Old Jul 19, 2011 | 08:59 PM
ddrumman2004's Avatar
More than likely a complete rebuild is in order.
Will the engine turn over? Can you turn it over with the pull start? If it will turn over, you could possibly get it to run but it won't run very well.
Since everything in the engine and transmission share the same oil, there could also be damage to the transmission gears as well as a load of other problems.
Old Jul 19, 2011 | 10:28 PM
jcdc04atv's Avatar
If it quit while you were using it, then it most likely will need a complete rebuild. since the damage is from lack of lubrication, the rebuild will be pretty detailed. From your comments, I would recommend you get an experienced mechanic to help you. You might check out the cost difference of a rebuilt engine instead of trying to do it yourself.
Old Jul 20, 2011 | 08:20 AM
i just recently hooked it up to jumper cables and tried to start it and yes it wanted to start but it wouldnt and to rebulid the motor how much money are we talking ?
peytonius
Sep 28, 2015 02:18 PM
colt1126
Aug 18, 2015 10:38 PM
Hondamx751
Aug 13, 2015 01:06 AM
MNatv89
Aug 10, 2015 02:20 PM
MNatv89
Jul 7, 2015 11:36 AM
