fourtrax 300 4x4 brake drum cover
Old Jul 22, 2011 | 09:35 AM
pacepace's Avatar
Default fourtrax 300 4x4 brake drum cover
I have a 1998 fourtrax 300 4x4 and i am trying to change the rear brakes on it but the brake drum cover will not come off. I thought it was just suppose to pull off but it will not. Is there a certain thing i am suppose to do?
Old Jul 22, 2011 | 11:18 AM
Sgro3533's Avatar
You've got to take off the two nuts on the axle that hold it in place
Old Jul 22, 2011 | 08:52 PM
pacepace's Avatar
i already did that and took all the bolts off around the cover it is stuck on there
Old Jul 22, 2011 | 09:25 PM
Sgro3533's Avatar
Did you take off the little skid plate under it? If so it should come right out. Pry it with a screwdriver
Old Jul 23, 2011 | 12:50 AM
TexasRoadlawyer's Avatar
No Ruts, No Glory
if EVERYTHING is disconnected, including the cable, then take a rubber mallet (NOT a hammer) and hit it as hard as you can a couple of times to knock it loose...you probably have some corrosion causing havoc with the inside of the brake drum
Old Jul 23, 2011 | 03:10 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Make sure you remove the little o-ring around the middle of axle that is recessed up in the drum! and than not come off drum is seized or the brake cam has got drum locked on or drum is worned down enough that won,t come over shoes..
fordfaithful21
Dec 7, 2015 05:52 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
