01 honda rancher not starting
Old Jul 25, 2011 | 08:54 AM
jeremymoore29's Avatar
Question 01 honda rancher not starting
I have a 01 honda rancher and a few weeks ago.I was riding and it died well I tried starting it and kept cranking and would not start well finally it did start and as soon as I touch throttle it dies again and takes alot of cranks to restart and idles fine just will not stay running when I hit throttle any ideas..
Old Jul 25, 2011 | 09:23 AM
ddrumman2004's Avatar
Could be a couple of things......
First, remove the fuel line to the carb and see how much fuel is flowing to the carb. There may be enough to get the engine running and allow it to idle but not enough to allow it to run above idle. Could also be that the vent in the fuel cap is plugged.
Could be you will have to remove the carb and clean it thoroughly.
Old Jul 25, 2011 | 01:13 PM
Ok I will check those out I put a new choke cable on also I appreciate the help will post again after checking those things out thank u
neilbedwell
Nov 10, 2018 11:02 AM
ROWALKER
Jun 15, 2015 05:38 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
aby11
May 7, 2000 07:58 PM
Rancheres4X4
May 5, 2000 02:09 AM
