scrambler gear grind
Old Jul 27, 2011 | 10:02 PM
dom088's Avatar
Exclamation scrambler gear grind
hey guys
i have a 05 scrambler 500... issue is the gear change... when changing the gear in to either D or R it will grind the gears.
how do we go about adjusting the clutch?
thanks guys
Old Jul 27, 2011 | 10:29 PM
dom088's Avatar
its the secondary clutch....
it does not spread open when in gear....
how do we adjust this?
Old Aug 14, 2011 | 02:37 PM
Forcedgto's Avatar
springs and weights are the culprit here... disassembly for inspection is most likely your best course of action
Old Aug 14, 2011 | 06:34 PM
Kerbbirds's Avatar
try slowing the idle down
Old Aug 14, 2011 | 11:31 PM
dom088's Avatar
we have done all of that.. seemed in fine condition to me...
once i stop the secondary from spinning it will shift into gear without grinds.... it spins too fast by itself.... it has to slow down...
idle is really low.
Old Aug 15, 2011 | 07:24 AM
Raven95150's Avatar
Sounds to me like the primary isn't releasing all the way, so the belt and secondary are still spinning at idle.
Old Aug 15, 2011 | 12:01 PM
dom088's Avatar
how do we go about that?
what should i do/check?
Old Aug 15, 2011 | 12:25 PM
TLC's Avatar
TLC
The shift lever has two lingage rods that go to the tranny with adjusters on both ends. you can fool with them to get it smoother.
let the ATV idle down and when shifting and give it a quick jerk on the shift lever, not a slow pull or push of the lever.
Old Aug 15, 2011 | 01:37 PM
dom088's Avatar
ya thats what we have been doing (the quick shift) its less of a grind but i still cringe when it grinds.
it would be nice to have this issue solved
Old Aug 15, 2011 | 09:31 PM
mrtwostroke's Avatar
i have no experience with new engine braking clutches. but what i hear is the piece that is supposed to spin in the bottom of the primary drive clutch is sticking. allowing the belt to move turning the sec.
