03 Predator Carb Leaking???
Old Jul 28, 2011 | 05:29 AM
captjanes's Avatar
Default 03 Predator Carb Leaking???
last year my carb was leaking badly through the drain in bottom of the carb.(not the overful). i replaced needle and seat and it slowed down but still didnt stop i cleaned the carb and still no stop so now everytime i stop i shut off the gas. what is causing this? i have a 03 KTM 250 sx that is doing the same.. maybe carbs just dont like me haha. but now the predator is not working right she is spitting and sputting on top end. please help
Old Jul 28, 2011 | 10:21 AM
Make sure the bottom of the float assembly is parallel with the carb body when carb is held upside down.Also check for any splits,cracks in the overflow tube in the lower carb bowl that could cause the leaking also.When was the last time you had the valves adjusted?? The Predator has to have this done frequently since its a shim under bucket system. Valves can tighten up and cause the spitting,sputtering. I've even had em come in not running from too tight valves. OPT
Old Jul 28, 2011 | 10:30 AM
captjanes's Avatar
what do i do if the float is NOT parallel?? i checked the valve lash it looked ok to me.. but i do valve lash on large 100,000HP sulzer diesel engines maybe there is a difference i dunno
Old Jul 28, 2011 | 10:58 AM
You can adjust the small tang on the float up or down to where the float assy is level when held upside down.The clearance on the the valves have a specific range on the intake and exhaust.You need to get the clearance range and check with feeler gauge,most of the time valves are too tight! You have to have access to different adjustment shims or let a dealer do it! OPT
Old Jul 28, 2011 | 02:19 PM
woodsidewarrior's Avatar
Maybe check to see if there is a o-ring on the seat of the float valve you need to remove the needle valve seat to check for it
Old Jul 28, 2011 | 05:24 PM
captjanes's Avatar
i checked valve lash intake .006" exh .010" so that is spot on. there is a new needle and seat and o-ring..
GregM
Mar 6, 2018 06:53 AM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
Unzzy66
Jul 11, 2015 10:01 PM
steveo612
Jul 11, 2015 08:35 AM
