110cc peace/ SOUNDS LIKE THE STARTER IS LOCKING UP?
Old Jul 28, 2011 | 09:52 AM
loadmaster6119's Avatar
Default 110cc peace/ SOUNDS LIKE THE STARTER IS LOCKING UP?
tryong to start and the starter just clicks. I am pretty sure its just the starter. Anybody got any links to a good place to order a replacment?
Old Jul 28, 2011 | 11:53 PM
LynnEdwards's Avatar
Electrical Expert
Find the postive battery terminal, and follow the big fat red wire to the starter solonoid screw terminal. Follow the other starter solenoid screw terminal to the starter motor.
Now take a screwdriver and use the shank to short those two screw posts on the starter solenoid together. Some sparking is OK.
Does the starter turn?
If it doesn't, use a pair of jumper cables to connect the quad battery to your car battery [take extra care to get the polarity right...]. Does the starter motor turn now?
Old Jul 29, 2011 | 08:41 AM
Lynn I Arced the started and tried Jumeper cables 1st thing... and it still sounds locked up....
Old Jul 29, 2011 | 08:44 AM
Lynn,
I Arc'ed the Starter 1st thing and then jumper cables......still sounds locked up?
Old Jul 29, 2011 | 09:05 AM
Jaster94's Avatar
so your battery is sitting there about 13 volts or so and the starter clicks or doesn't move. you've tried jumping the solenoid and it clicks or whatever. right? i have a Linhai quad doing the same thing, i've got a bad solenoid because i've pulled the starter and tested it on the ground with jumper cables and it turns over/cranks just fine. if you don't want to pull the starter to test it, replace the solenoid (starter relay). just make sure your battery is charged up. if your quad has a ripcord/pull start rope, turn the engine over and then try the starter, maybe it's hung up. good luck.
Old Jul 29, 2011 | 09:08 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Does the engine turn over by hand?
Old Jul 29, 2011 | 11:06 PM
Electrical Expert
Use a meter to measure the DC voltage right at the starter motor while trying to start it up (solenoid clicked in, or use a screwdriver to jump across the solenoid screw posts). Put the meter red lead on the starter input post, the black lead goes on the starter motor metal case. What do you measure?
If you get 12 volts right at the starter motor and the starter isn't turning then that leaves a bad starter motor, or the engine won't turn (which I think MWQ was hinting at when he asked if the engine turns by hand).
STLyamwar
Jul 25, 2020 04:44 AM
ghost civic
Jan 15, 2020 07:43 AM
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
