Infamous Sportsman 500 HO Ticking now Gone!
Old Jul 28, 2011 | 01:54 PM
PolarisRich's Avatar
Default Infamous Sportsman 500 HO Ticking now Gone!
Hey Guys
I just wanted to let all you Polaris Sportsman 500 HO owners know what I came across today while working on my bike.
I decided to pull the bike out today to start getting it ready for my trip up north next week. When I started it up I noticed the infamous Polaris Sportsman ticking that comes from the front right of the engine. From what I read on all the different forums is that the ticking is from the water/oil pump. I also read that this sound is normal on most SP500 HO's and so I thought I would have to live with the sound. But what I did notice when I started the bike was the noise was a bit louder than I last remembered it to be.
So I decided to changed the oil and I followed the procedure in the manual right to the letter! I used a K&N oil filter and 2 liters of Amsoil 0W40 4 stroke synthetic. When I was done changing the the oil I pinched off the vent line to the top of the oil tank to prime the oil pump and started the bike. I held the vent pinched for around 15 seconds and released it untill I heard the air release sound. Now the pump is primed and the oil is flowing like it supposed to be but the infamous ticking is still there but a little quieter. This difference in sound had got me thinking about what could be causing the noise and what I came up with is a air pocket that is trapped in the oil pump.
You may think that sounds a little far fetched for air to be trapped in the oil pump, but what I did next seems to have solved my ticking noise. I started the bike and I pinched the oil return line that comes from the pump and goes to the tank. I only pinched it off with a pair of needle nose pliers for a few seconds at a time. Each time I pinched the hose the tone of the engine would change and sound as if it was loading up. I also noticed the hose expanding slightly from the oil pressure, when this happened I would release the hose and you could hear the oil rushing back into the tank. After doing this about 5 times my ticking was 95% quiter if not completly gone.
Now I don't know if this will work on everyones bike but it seemed to work on my bike and I now love the sound of my bike, it sounds like new again!
P.S. If anything changes on my trip next week I will post back my findings.
I hope this helps!
Rich
Old Jul 28, 2011 | 05:56 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
interesting idea. thanks for sharing.
Old Jul 28, 2011 | 10:44 PM
Interesting? Not trying to throw a monkey wrench into this,BUT its possible that as you squeezed the return line to the tank (which will build up pressure in the pump) that the increased pressure could have opened up a partially blocked oil jet leading up to the head (cam area especially) which could quieten down the valve train noise?? I've torn into a bunch of oil pumps and its a simple inner and outer pickup and push centrifugal rotor system that would push air,oil,water!,basically anything except mud through it!
Possibly the noise you were hearing was valve clatter or ticking maybe radiating downward??? Just thinking out loud again! OPT
Old Jul 29, 2011 | 08:22 AM
Well you might just be right about some of that. I`m just glad that the ticking noise is gone! But I am thoroughly convinced that the ticking was not coming from the valve train. I used the old screwdriver to the ear method to determine that the ticking was coming from the water-oil pump housing. Still in the long run the noise is gone and the bike sounds great.
Old Jul 29, 2011 | 12:36 PM
As long as your happy with it and its running good,that's all that really matters! Good luck OPT
Old Jul 29, 2011 | 12:38 PM
Thanks OPT
I'll post if anything changes after my trip next week!
Jmuddin284
Jan 19, 2026 07:16 AM
Tomtom86
Aug 7, 2024 07:40 PM
Big bousse
Sep 26, 2015 10:42 AM
cdstang
Aug 31, 2015 07:52 AM
MNatv89
Jul 7, 2015 11:36 AM
