compression release ball bearing
Old Aug 1, 2011 | 02:27 AM
sies59's Avatar
Default compression release ball bearing
Does any one know where i can get compression release valve for the camshaft polaris sp 500 98 i found out they come with the camshaft, does any one know who might make them i read that a HO cam fits into a 1998 sportsman500 which model HO ill have to replace the shaft if i cant get a valve cheers
Old Aug 1, 2011 | 06:56 AM
Part# 3085348 for the lever, #3085076 for the spring,BUT the detent ball as mentioned before is not sold separately! Try a salvage yard or see if a dealer has an old cam laying around you can take parts off of!! Levers and springs are the same as on a HO cam,just the cam hardness and slight lift change is the only thing different! OPT
slowgsxr97
Mar 18, 2022 03:40 AM
STLyamwar
Jul 25, 2020 04:44 AM
Divergent12
Dec 30, 2017 08:33 PM
toonces
Dec 15, 2015 03:59 AM
Chuck188
Jul 17, 2015 02:45 PM
