Prairie 650/750 Ignition fit 360???
Old Aug 5, 2011 | 03:49 PM
AFRAID2FLY's Avatar
Default Prairie 650/750 Ignition fit 360???
My belt sensor will not reset even after doing the reset procedure several times. Belt is within tolerance. I heard Dyna makes an ignition that will eliminate the 100 hour mandatory limp mode..but they only make it for the bigger quads.. Any help would be appreciated..
Thanks,
Tim
Old Aug 8, 2011 | 09:26 AM
Hayashi's Avatar
I think you are misinformed....
100 hr belt check (steady) light does not cause LIMP home mode. Flashing light does.
What do you mean by changing the "ignition"? Ignition key or igniter?
Ignition key has nothing to do with the belt light. Igniter does.
Bigger quads (650, 750, etc) igniter does not work on 360.
If your 360's belt light does not reset even if you follow the correct procedure, then the belt switch itself needs to be replaced.
Old Aug 16, 2011 | 12:20 AM
AFRAID2FLY's Avatar
Sorry I meant Ignitor. Will try the the belt switch itself. Dyna makes one that does away with the Limp mode, but not for the 360.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
Sw00p
Sep 24, 2015 02:50 PM
