1985 TRX 250 problems
Old Aug 9, 2011 | 06:06 PM
omega45820's Avatar
Default 1985 TRX 250 problems
Hey all new here and have a problem with this atv i just got..
Before it quit running i had checked everything on it and everything was fine it was charging and getting good spark.. i changed the oil to 10w 40 synthetic and it ran fine for a hour or so and now after i start it it will run for maybe 2 mins then dies... i checked to see if it was getting spark and no spark but after i wait for like 15 mins i can get a couple sparks and that is it....ive checked the coil and everything and it is fine...do you all think it could be because the oil
thanks all
Old Aug 9, 2011 | 06:38 PM
budedm's Avatar
It can't have anything to do with the oil. Have you put a new plug in it?
Old Aug 9, 2011 | 06:40 PM
omega45820's Avatar
yea i put a ngk back in it and made sure the gap was right....i can pull the plug out and lay it against engine and it will spark for just a sec while cracking then it just quits then after a couple mins same thing and quits again
Old Aug 9, 2011 | 06:44 PM
foxracing12's Avatar
Check the cdi box that will do that
Old Aug 9, 2011 | 06:50 PM
omega45820's Avatar
how do you check the cdi
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Dustinyoungs
Jul 24, 2015 07:18 AM
hondarider1234
Jul 21, 2015 11:53 PM
CRamshaw777
Jul 18, 2015 05:46 PM
HondaR24
Jul 16, 2015 10:45 AM
