94 TRX300FW Will not start
Old Aug 10, 2011 | 03:33 PM
hotrodman's Avatar
Default 94 TRX300FW Will not start
Help! 94 TRX300FW has good batttery, new relay, good fuses but only "clicks" when engaged..Did get it started for 5 min. w/start button by manul turning engine one kick but it died and would not restart, only "click". Any ideas???
Old Aug 11, 2011 | 06:36 AM
papa hogg scoot's Avatar
Loved
Community Favorite
Take an test light an probe the stater wire and push the starter switch button if the test light lites up when you push starter button then your brushes is bad or brushes are sticking, IF not lite up than you have an wiring or relay bad.
Old Aug 12, 2011 | 03:59 PM
hotrodman's Avatar
I did as you suggested with test light. Starter was bad. Replaced it and it still will not engage. No more clicking from the relay --now getting a "buzz" instead from relay. Its a new relay but it could be bad. Ant way to check it? Any other ideas?Thanks again for the help!!
Old Aug 13, 2011 | 08:31 PM
Loved
Community Favorite
Yes! Okay read real close, Take relay off than take an paper clip and put in the two small wires,than take volt meter with an buzz box in it or do an conuity test with ohms.K get an batt put some jumper wires with gator clip on them PUT on the small wires,Than take the meter and put on the big post and if relay is good the buzz will go off or conutiy will read on meter! sometime an relay will click but won't touch the bigger post inside to send the volts to starter.You are just making relay to work backward so you can read it! Good Luck keep us updated.
Old Aug 16, 2011 | 10:33 AM
hotrodman's Avatar
Found the problem to be a bad starter that when replaced a fiber washer--don't ask me why, I don't have a clue why--was placed on the starter stud that is used for a ground whereby causing a bad ground!! Removed washer altogether and it starts and runs fine! Thanks for the help Papa Hogg Scoot!! Also thanks to ATV Connection Magazine for having these forums that help so much!! You'all HAND now, you hear!!!!!!
Old Aug 16, 2011 | 11:17 AM
mouse4x4's Avatar
Good job helping him out need more like you around that help and not want to start drama
Old Aug 16, 2011 | 10:09 PM
Loved
Community Favorite
Thanks for the comments! Glad to help when i can! Hot rod man you are very welcome! Iam so glad you fount the problem. Your the one thats needs the HAND.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
