angle sensor keeps going out
Old Aug 10, 2011 | 07:35 PM
danbennett's Avatar
Default angle sensor keeps going out
hi everybody, I have a 2006 honda rancher 400at. i had recentley replaced the angle sensor in it when my reverse wouldnt work right. it seemed to have solved the problem, temporarily. after about 50 miles with the new sensor, i have the same problems again. does anyone know what would make it go bad again shortly after replacing it? Thanks alot y'all. Dan
Old Aug 10, 2011 | 08:27 PM
nicholstrx400's Avatar
how much will an angle sensor set u back? i jus traded a bog truck four a rancher and have been having problems with the at (prolly why they were so keen on trading) i think it needs an angle sensor called the local honda dealer and they wanted 100 bucks seemed a lil steep to me
Old Aug 10, 2011 | 09:28 PM
wydglide's Avatar
have you tried applying dielectric grease to the wires to keep the connectors dry? do you do a lot of mud riding, or I guess I should ask what type of riding are you doing when it go's bad?
if the angle sensor keeps getting Very wet it will not work correctly......but most of the time if you allow it to dry it will work proper again or turn off the key for a few and try it again....just a few of the things you can do in the field to test it, also are you getting any type of beep codes?
as far as price $100 is WAY too much go here and have a look at part #24, their $44.95 on this site, this might help you find one that's NOT over priced
NOTE: this is for my '09 500 , but I'm sure you can find your part very easily by starting here!
Lowest price guarantee on parts / accessories for Honda Motorcycle, ATV, Watercraft, Scooter - OEM parts for less
Best of Luck
Glide
Old Aug 13, 2011 | 05:00 AM
jcdc04atv's Avatar
Just replaced one on our 09 Honda 420 and it was $58 plus labor. Evidently it is in a location that mud and dirt can get to it very easily and can damage it.
Old Aug 13, 2011 | 05:39 AM
wydglide's Avatar
yea I knew $100 was too much for that part, their simple to change........
flip the Quad on its rear bumper remove the belly panel/skid plate it right their in your face. (again on the 500's)
Best of Luck guyz
Glide
Jeff Roper
Feb 1, 2022 11:48 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
60
Dec 14, 2019 06:13 PM
Jeff Roper
Sep 21, 2015 02:11 PM
