help with honda motor
Old Aug 10, 2011 | 08:29 PM
MACTD's Avatar
Default help with honda motor
while replacing rings on piston the crank rotated is there a way to make sure the motor is TDC of compression stoke.
Old Aug 11, 2011 | 05:55 AM
budedm's Avatar
Well, normally you would be at TDC when both valves are closed. But since the valves aren't on yet, I don't think there's a way to tell. But, why do you need to be at TDC to replace rings? It doesn't matter. Just put them on, drop the piston in, and then put the valves & head back on.
Old Aug 11, 2011 | 03:18 PM
Doctorturbo's Avatar
GOT BOOST!
Yes there is. LOL, when the piston is at the top of the stroke and won't go up any higher; your at TDC.
Old Aug 11, 2011 | 07:14 PM
woodsidewarrior's Avatar
Mac I think I know what your asking the crank doesn't care what stroke it is on as long as it is at tdc the compression or exhaust stroke is determined by the position of the cam when it is at tdc
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Jul 22, 2015 05:00 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
ghost civic
Jul 15, 2015 10:48 PM
