2004 Sportsman 700 EFI
Old Aug 14, 2011 | 08:21 PM
allenbarney's Avatar
Default 2004 Sportsman 700 EFI
I just got this machine this winter and it runs great when I am at my house but as soon as I take it to higher elevations it starts cutting out and dies. Then I have to let it sit for five minutes before it will start again. Does anyone know what this could be and how I would fix it.
Old Aug 14, 2011 | 08:32 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
What kind of elevations are you talking about? Sometimes you would need to rejet for the elevations. I believe most bikes come preset for 0'-3000'.
Old Aug 14, 2011 | 10:47 PM
My house is 5000 and we go to 6000
Old Aug 15, 2011 | 07:03 AM
Spdecat's Avatar
Can you rejet a EFI machine , I thought the whole point of buying EFI was for the fact that it automatically adapts to elevation changes ?
Old Aug 15, 2011 | 07:19 AM
TLC's Avatar
TLC
Is that under this ECM recall?Polaris Expands ATV Recall
When that brain box goes screwy many other things do as well.
Old Aug 15, 2011 | 05:07 PM
Recall only applies to carb models not efi systems.
Old Aug 15, 2011 | 08:29 PM
Doh! I suggested trying to rejet an EFI. which I'm pretty sure wouldn't work. My mind instantly thunk carb model for 2004.
Old Aug 17, 2011 | 08:40 AM
So how would I fix the problem it is having?
Old Aug 17, 2011 | 09:53 AM
Check the fuel tank vent that runs into the headlight pod area for any kinks,could be just getting enough air to run a short time in high altitude then will die until enough air is built back up for fuel flow. If vent line is clear,then could be fuel pump getting weak. OPT
Old Aug 17, 2011 | 03:46 PM
Wheels47's Avatar
Bingo! I would think that it is vapor locking in you.
