Polaris 2005 700 Sportsman EFI
Old Aug 17, 2011 | 09:06 PM
taffy1115's Avatar
Default Polaris 2005 700 Sportsman EFI
I have a Polaris 2005 700 Sportsman EFI that runs great and has working front lights. The problem is the brake and running lights and reverse light do not work All of them are out. The dealer said it most likely is the Power Distributions Module. Does anyone know if it could be something else before I go and replace the beast that is pretty pricey.
Old Aug 18, 2011 | 08:51 AM
First off did you check the fuses under the front panel? If fuses are all good then check the harness area under the headlight pod area. This area receives the most movement and can have shorts or ground problems causing the lights not to work? OPT
Old Aug 18, 2011 | 09:45 AM
taffy1115's Avatar
Default 2005 700 sportsman rear lights dont work
I did check the fuses. I replaced each one....one by one and tried the lights. No luck. Will check the harness.
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Coryco
Jul 6, 2015 07:30 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
