07 500 efi electrical problems
Old Aug 20, 2011 | 09:00 AM
badazz400's Avatar
Default 07 500 efi electrical problems
well well well........ Here I am again...........
I go out in the shop yesterday and decide to take the sportsman for a cruise (keep in mind, I just fixed the starter).
I check the oil. turn the red engine start button on and turn the key over and I have nothing. No fuel pump, no screen, nothing. So Im thinking dead battery. I jump the scilonoid and the motor turns over great.
So I leave the key on and as im inspecting the bike everything comes on. then cuts off. then cuts on. then cuts off. then cuts on. While its doing this im hearing a sound coming from underneath the handlebars. it sounds like my home computer when you first turn it on. booting/loading up. making those funny "computer noises" when the screen did come on the check engine light did not. and no number codes were thrown at me
I disassembeled the headlight cover and wiggled all the wires and made sure everything was tight. battery terminals and scilnoid are tight.
any suggestions????
all replies are appreciated.
thanks
ross
Old Aug 20, 2011 | 09:39 AM
Pull the connectors from the left control switch, ecm and the control module,use die electric grease around connectors and plug back in. If doesn't help,could have a short in either the ecm or control module itself triggering internal circuit breakers or short in the wiring harness under the pod area leading to the modules.Or could have a short in wiring from left control switch down into the pod area. I've had quite a few harness shorts under the pod area on efi and non efi machines as its subject to the most movement. OPT
Old Aug 20, 2011 | 03:41 PM
badazz400's Avatar
Pull the connectors from the left control switch, ecm and the control module,use die electric grease around connectors and plug back in. OPT
thankS OPT! which module is which and where are these items located on the machine?
Electrical never has been my virtue and theres so many plugs. just want to make sure I got the right ones before I go pullin and cleanin.
Old Aug 20, 2011 | 07:45 PM
Both big modules are under the front panel. The one up by the steering post is the ecm, down by the radiator is the control module. Plus use electrical grease on left control connectors,Plus wont hurt to lube any connector you find. Hopefully your problem is something simple! OPT
Old Aug 21, 2011 | 07:59 AM
badazz400's Avatar
thanks opt!!!! ill keep you posted.
Old Aug 26, 2011 | 08:50 AM
badazz400's Avatar
well, I swallowed my pride, bit the bullet and put her in the shop.
All them wires and plugs is above me. When I get her back, I'll let you guys know what it was
Old Oct 10, 2011 | 10:58 AM
badazz400's Avatar
welp. turns out my problem was a bad power distribution module.....
800 bucks later and the quads home.
now it seems as if my fuel guage isnt reading correctly, the reverse overide button doesnt work. when you press it tje dispay doesnt show rpm, hrs, miles or time. its just stuck on trip odo.
other than that the bike runs fine
any ideas as to what this could be?
thanks opt!
Old Oct 10, 2011 | 02:24 PM
Was speedo ok after the module change? Try disconnecting battery for a few minutes,hook back up and check speedo. If doesn't help, still could be a short in the harness around the pod area, a problem in the left control switch(yellow button wiring?) or the speedo itself could be the problem? OPT
Old Oct 17, 2011 | 07:35 PM
badazz400's Avatar
Well I replaced the control switch and that fixed my display problem. the tach, odo, etc work with the press of the override button.
forgot to look at the fuel guage but if it doesnt work I think I can live without for a while. Im ready to let this mo fo eat!
I'll know more next time I ride it but Hopefully, (knock on wood) Im squared away .....for now
thanks opt!
Old Oct 17, 2011 | 11:06 PM
Sounds like you've spent enough $ for awhile! Hope you get some riding time now!! OPT
