Wide Tires
Old Aug 25, 2011 | 06:38 AM
Dylan Robinson's Avatar
Default Wide Tires
Was shopping for tires lately and trying to decide what is the widest tire I could get for an 05' 700 sporty. Is anyone running 27/12/12s all the way around??
Old Aug 25, 2011 | 07:51 AM
TLC's Avatar
TLC
Might need wheel spacers for the front, but the backs should be good, I have 11" wide rear tires with lots of room to spare to go wider. 12" would only be 1/2" wider on the ATV side of the tire vs 11s.
Not sure your arms and steering ball joints and other components would like heavy 27" high and 12" wide tires on the front. LOL
Old Aug 25, 2011 | 08:43 AM
Yeah I'm sure accelerated wear would be a factor. I'm running 27/11/14s on the rear right now. The other day just for fun I pulled them off and stuck one on the front. pretty sure I could get away with that if I flipped the tie rod end. But I would really rather have 12in wheels for the taller sidewalls, and better tire selection. I was just curious if someone had tried 12s already. Guess I just need to borrow a wheel from somebody and mock it up to see what I can get away with. Don't really want to run spacers if I can help it.
Dylan
Old Aug 25, 2011 | 02:47 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Yikes man! I've ridden a sportsman with 10" wide up front and the steering felt a little stiff and heavy. I couldn't imagine going to a 12" wide. Especially in rugged terrain.
Old Aug 25, 2011 | 04:54 PM
Tonyxp's Avatar
If you want to go 12 inches wide you will need spacer s in the front. The rear will be fine. I believe anything wider than 10 you will need spacers. I needed them with 10 titan 589, and my buddy has 10 inch wide outlaws and needs spacers.
Old Aug 25, 2011 | 06:57 PM
Must be on 12" wheels right?? Any idea what the backspacing is??
Old Aug 25, 2011 | 07:36 PM
Tonyxp's Avatar
I am pretty sure they are both 4-3 offset. Not sure which way that is. If it is 4 inches or 3 inches out. I know they are both on itp rims.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
