TPS sensor adjustment on a 2007 Sportsman 800
Welcome to the forum! If the tps sensor bolt is loose then just tighten,try not to move the sensor! If adjustment is needed(not running right) only a dealer supplied harness that sets it to factory specs is needed. It comes with the harness,regulator,connection for 9 volt battery to be used with a volt meter. I'm not sure if SPX tools offers this or not? You can order this through a dealer,just depends if you will need it again?? OPT PS. Sorry about the earlier post,I was thinking the speedo sensor bolt was what you said was loose!
bzdok1234
30
Feb 23, 2016 01:55 PM
