Im new here need help with 300ex 1991
Old Aug 26, 2011 | 10:05 AM
switch99's Avatar
Default Im new here need help with 300ex 1991
Hi everybody nice site here
i got a question my 300ex will not full throtle in any gear but if full throtle it out of gear it will stay full throtle but not at half it just spits and sputters i.replaced a solenoid on it and ive been reading up and found all kinds of stuff on what it could but i caan not figure it out is there anything that could cause it to that i have cleaned out carb and everything oh yeah and the jets inside of carb does the center jet the main have to b at a certin adjustment or all the way snug
Old Aug 26, 2011 | 04:53 PM
budedm's Avatar
The main jet gets screwed in all the way. Is it getting enough air? Is the filter clean? Other than that, I don't know because you say you have cleaned the carb.
Old Aug 28, 2011 | 10:33 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
I have had 3 EX's and currently have a 96 EX. I love em!
Providing that there is no issue with air going in and out (air filter/air ducting/pipe)::
I'd be looking at the compression. Whether it's a wore piston or valve.
OR VALVE ADJUSTMENT. hehe
But it could be a bent/broke/wore/sticking valve. I find it hard to believe the timing chain slipped a notch.
I consider the valvetrain bulletproof for the most part but being a 91, things wear out.
I'm sorta betting on the piston.
Hope that helps.
P.S. Using periods helps. I understand you know what is being said, but we have to read it a few times to understand.
Old Aug 28, 2011 | 12:31 PM
budedm's Avatar
There IS a valve adjustment procedure for the 300ex. Don't remember what the measurement is but I DO KNOW that they need to be adjusted periodically.
Old Aug 28, 2011 | 01:02 PM
LT80's Avatar
LT80 Expert
I stand corrected. Thank you.
I went to look in the parts bin. No valves/rockers but I did find the clymer manual.
It calls for .004 valve clearance.
I also found the EX head I ported for the boy. Took 2nd at the Red Bud national with it.
Pehter
Oct 3, 2024 11:00 PM
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
wendal
Sep 15, 2015 01:50 PM
